Tech@ZWO. Setup: EDGEHD8 native focal length. Image train in order from OTA: celestron T adapter -->CAA-->7x36 EFW-->2600mm pro. I have an EAF pro installed. As you can see in the photo (photo 1) - when the CAA rotates the image train - the EFW just clears the EAF; however, it has to be unplugged or it will run into the power and temp probe cables. It's fine to unplug the power on the Pro model, but now I cannot use the temp probe cable.
The "coupler" is your connection from the EAF Pro to the focus knob on the HD8 - see photo 2. If the coupler was shorter, I could move your adjustable bracket forward and give more clearance.
Software - ASIAIR, the most recent beta, I believe 2.4.4. Yes, 180° CAA is supported, but it's not user defined. It just picks 180° based on where the camera is sitting for the first frame. There should be user defined limits of rotation to toggle to prevent the CAA rotating one direction or another or the real fix would be a shorter coupler.
Thanks!
