Can I please make a suggestion to make the PA fine tuning a bit easier to see. When we’re very close to optimum adjustment, it is impossible to distinguish in which direction to make an adjustment. It would help if each green circle had a unique color and a third color where they overlap. That way a sliver of different color is easy to detect and correct for. I assume some are happy when within a degree but part of my hobby is to do the best I can … OCD ? Maybe 😉
There will also be direction prompts for you during fine-tuning, but the adjustment range must be extremely small. Regarding the color-related issue you raised, I will record your needs. Thank you for your suggestion.
Thanks for considering.
