Can we have the leveling info within the stargazing window? Sometimes when you level the scope while closed, it is good, but when the scope opens and shifts the center of gravity, the leveling changes and there is no way to know about it while taking pictures. So, perhaps make "Leveling mode" where the scope opens half way -> level using the tripod -> scope opens fully and makes a full 360 slow rotation (the lens would move up and down during that time) while recording the level values and deterimes of the leveling is acceptible in all positions -> fine adjust the tripod to achieve good leveling in all positions. Maybe also while leveling mode is active, let the scope open for 10 seconds to check for shaking, so if there is big jumps during those 10 seconds, it may prompt the user to ground the tripod better. Additionally, during the leveling procedure, it may provide suggestion what would be the best "shutter speed" (10, 20 or 30 seconds). Such mode may be introduced for the 20 and 30 mode, where ideal placement and leveling is crucial.
Perhaps even during stargazing, if the leveling becomes higher than 2, it can show a warning message that the scope is not leveling anymore.
I would rather spend 10 minutes to achieve perfect leveling than to be frustrated during stargazing when images fail.
Additionally, can it be possible to pause the stargazing, for example when clouds appear or if its possible to continue a session another time.
