I would very much appreciate it if you could also set the gain of the guiding camera per filter in the autorun, in RGB I need a low gain, e.g. 100, but for Ha, Sii and O3 I need a very high gain, e.g. 450.
As it is now, I can't run an autorun with all filters, because the guiding then no longer works when I switch from RGB to narrowband, because then it can't find a guiding star. The other way round, from narrowband to RGB, the image is overexposed and the guiding doesn't work either.
This topic has been raised before but there has been no update.
