After I use the ai decoding on the Seestar s50. I push Moments and it says I need the app. Where is the app?
The error appears simply because you have not installed or connected correctly to the Seestar application, just download and open the app, connect to S50 to use Moments.
Thank you, I will try that. Hopefully it will work out
