Could you please let us know if you switched modes after the unit completed its homing process? Also, could you describe the noise in more detail? From your description alone, it’s difficult to determine the cause.
It may be normal grinding sounds during startup, but to be certain, you could contact our technical support and provide a short video or audio recording of the noise. This will help us confirm whether it’s a normal behavior or requires further attention.
