It seems that the issue might be related to your router’s IP subnet.
Seestar does not support connecting to Wi-Fi networks in the 10.0.0.x subnet (for example, 10.0.0.184). If your router is using this subnet, it may prevent the Seestar from connecting.
Could you please check what subnet your home Wi-Fi router is using?
If it is 10.0.0.x, you can try the following steps:
-Log in to your router’s management interface.
-Go to Advanced Settings > Network Parameters > LAN Port Settings (the exact path may vary by router brand).
-Set the LAN port configuration to Manual and change the IP address to a subnet outside of 10.0.0.x.
-Save the settings and restart the router. Then try connecting your Seestar again.
This often resolves Station Mode connection issues.
