I have damaged my USB-B port in my AM3. Is possible to connect it to ASIAIR using EQDIR cable? Will it have the same functionality like USB cable connection?
Regards - Piotr
Have you tried connecting the AM3 to the ASIAir via Bluetooth? I connect my mount to the ASIAir via Bluetooth without the USB cable. It works great. If you want us to work on it, please complete a RMA. https://rma.zwoastro.com/#/
My ASIAir (2022 model) has probably no Bluetooth, so I couldn't connect to it. However I was able to connect via WiFi and it seems to work fine. Need to test this in a field.
