Y9l7KSV8
Hello, the AM5N can be fully equipped with the ff130Apo or ff107Apo
The choice between 130 and 107 depends on your composition requirements. What kind of target equipment combination is suitable for shooting in your current area and whether the field of view meets your communication needs.
If you are considering cost performance, I recommend that you use the 2600 (aps-c) and FF107Apo, installing a 0.7x defocusing lens. It can meet the composition needs of most photography enthusiasts. This solution has a relatively high cost performance.
Of course, if you have sufficient funds, you can definitely upgrade to the 6200 (full-frame) with the FF130Apo. This combination will have a better shooting effect, but the price will also be higher.
