I have tested it a few days (nights): It works fine: Here is a picture of M74 (Phantom Galaxy) The picture is stacked with 4 S50 fits in Siril (totally 23h exposure time) Temp < 0°C
The connection is very easy:
- Use an (old) USB-cable,
- cut the connector you don't need
- use the cables with 5V(usually red + and black -)
- find an appropriate plugin connector for the battery connector of S50 (I used one not very appropriate - quick and dirty)
- connect red (+) with the red cable of the battery,
- connect black (-) with the black cable of the battery. (The yellow cable is for sensing the degree of loading of the battery.You don't need it.)
- plug in and close the housing of S50
It works even if you use the 5V of the USB cable. (The battery delivers only 4.3V.)
As I noted above: The degree of loading seams to be calculated (under these conditions), not measured: It steps from 100% to 0% in a few hours and remains at 0%. But everything (even remote connection via network) works as expected.
For all of you, who tries to replace the battery this way: If you blow your S50: don't blame me!
You do it on your own risk: NO GUARANTY!
curtismacc What do you see for the temperature on the App now?
I don't see any temp on the App.
