here is the message that comes in the exception window
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at ASCOM.ASIMount.FormSetupDialog.SetUI(CMD_ACTION action, String strData)
at ASCOM.ASIMount.FormSetupDialog.GetInitValue()
at ASCOM.ASIMount.FormSetupDialog.InitUI()
at ASCOM.ASIMount.FormSetupDialog.timerSingleShot_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.9221.0 built by: NET481REL1LAST_25H2
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
ASCOM.ASIMount.Server
Assembly Version: 6.5.25.0
Win32 Version: 6.5.25
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/ZWO/ASIMount/ASCOM.ASIMount.Server.exe
System
Win32 Version: 4.8.9321.0 built by: NET481REL1LAST_25H2_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ASCOM.Attributes
Assembly Version: 6.0.0.0
Win32 Version: 7.1.0.4707
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Attributes/6.0.0.0__565de7938946fba7/ASCOM.Attributes.dll
ASCOM.ASIMount.Telescope
Assembly Version: 6.5.24.0
Win32 Version: 6.5.24.0
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/ZWO/ASIMount/ASCOM.ASIMount.Telescope.DLL
ASCOM.DeviceInterfaces
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.DeviceInterfaces/6.0.0.0__565de7938946fba7/ASCOM.DeviceInterfaces.dll
ASCOM.Utilities
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Utilities/6.0.0.0__565de7938946fba7/ASCOM.Utilities.dll
System.Core
Win32 Version: 4.8.9319.0 built by: NET481REL1LAST_25H2_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.9221.0 built by: NET481REL1LAST_25H2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
InTheHand.Net.Personal
Assembly Version: 3.5.605.0
Win32 Version: 3.5.605.0
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/ZWO/ASIMount/InTheHand.Net.Personal.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Newtonsoft.Json
Assembly Version: 13.0.0.0
Win32 Version: 13.0.3.27908
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/ZWO/ASIMount/Newtonsoft.Json.DLL
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
ASCOM.Astrometry
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Astrometry/6.0.0.0__565de7938946fba7/ASCOM.Astrometry.dll
LibBle
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Common%20Files/ASCOM/ZWO/ASIMount/LibBle.DLL
Windows.Devices
Assembly Version: 255.255.255.255
Win32 Version: 10.0.10011.16384
CodeBase: file:///C:/WINDOWS/system32/WinMetadata/Windows.Devices.winmd
System.Runtime
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.dll
Windows.Foundation
CodeBase: file:///C:/WINDOWS/system32/WinMetadata/Windows.Foundation.winmd
System.Runtime.InteropServices.WindowsRuntime
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.InteropServices.WindowsRuntime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.InteropServices.WindowsRuntime.dll
ASCOM.Exceptions
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ASCOM.Exceptions/6.0.0.0__565de7938946fba7/ASCOM.Exceptions.dll
Anonymously Hosted DynamicMethods Assembly
Assembly Version: 0.0.0.0
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
