I have the CAA attached in this order: RedCat 51 -> CAA -> EFW (5x2") -> ASI2600MC Pro. The CAA has the base / power input section at the bottom and the EFW is rotated so that its base is at the top (ie. 180 degrees). The camera is screw fixed with the long edge of the sensor running horizontally. Everything is aligned and in my mind the camera orientation should be 0 degrees regardless of any plate solve. Can the UIx on ASIAIR Plus for CAA configuration be changed so that I can specify the camera zero position and the start and end limits from that position so that my EFW or its USB connector doesn't crash into my AM5N? This video illustrates the ideal solution:
[https://youtu.be/9y1Ag7C8Zmo?si=QPyJ0yN4DU2fYrPJ]
I cannot find any workflow in ASIAIR 2.4.4 that would allow override of CAA camera position or angle limits. I tried the EAF hand controller, which does allow some control override but even then it will bump up against a hard stop where the CAA currently thinks its at the zero position. I cant configure the CAA on any other software, like NINA as in the video and then reconnect to ASIAIR since the CAA has no onboard configuration storage.
