PMTeam@ZWO
https://www.yuque.com/zwopkb/asiair/homepage
Last updated in 2021 for the most part and not even readily available on the website? The hardware and software has moved on a bit since then.
Thanks, but no thanks.
The Support section on the website also needs a major overhaul. It's a total mess that requires hunting around for basic information hidden throughout multiple FAQs articles and User Guides. Simply adding more articles and random appendices as time goes by is making things more confusing for new users.
As an example:
I very recently asked support directly for the best start-up routine for my rig when adding the CAA. The CAA was losing it's bearings and behaving erratically during guiding. We did the usual back and forth to eliminate obvious problems with the settings that I'd already checked and confirmed. Send some logs that didn't help.
Thankyou to support for being quick to respond and trying to help. The problem is that I didn't get an answer to my initial question. 1,2,3...and then?
From what I can tell so far, I simply needed to add an extra plate solve and sync after my usual setup routine. Not something that I've ever needed to do in the past. If it ever clears up and stops raining I'll be able to confirm this with further testing, although we've now moved onto a newer firmware and app version, so who knows.
Having a proper manual that is constantly updated as the software and hardware evolves is a no brainer. It would make life that much easier and get back to the simple as 1,2,3 solution.
There'd be less support requests and you've got enough users that would no doubt step up to do most of the work for you. How hard could it be?
