ASIMount-ZWO This post is good news, but seems to me as lacking how to upgrade the mount's firmware.
I'm seeing the same issue with PulseGuide commands returning OK but no actual movement on my AM5N—did you ever get a response from the team about whether this is a known limitation in 1.8.8 or if there's a specific setup requirement we're missing?
I'm seeing the same issue with PulseGuide commands returning OK but producing no actual movement - did you ever get a response from the team on whether this is a known limitation with the AM5N specifically, or if there's a workaround you found?
