I will be observing from Northern Spain and I am using an S30 Pro. Here is an eclipse day cue card on how to capture using time lapse mode (you will need to adjust times for your exact location):
Eclipse Day Cue Card — Ranón, Asturias — Aug
12, 2026
Approximate local times below (partial start 19:30, totality 20:27–20:30). Confirm exact
contact times for your precise coordinates 1–2 days out — they shift by seconds depending on
exact viewing spot.
T-minus 60 min (19:30) — Partial phase begins
Solar filter ON, telescope pointed at sun
Start Time-lapse mode: 2s interval, Unlimited duration
Let it run hands-off. Put your phone down, watch with eclipse glasses.
T-minus 10 min (20:17)
Check framing/focus one more time
Confirm timelapse is still running and storage has space
Scan the western horizon for haze/cloud — decide now if you need to move to backup
spot
T-minus 1 min (20:26) — 2nd contact approaching
Do not touch the filter yet — wait for visual confirmation (rapid darkening, shadow
bands,
"diamond ring" appearing)
The instant it's safe: remove solar filter
Keep Time-lapse running continuously through totality — don't stop/restart it
Totality (20:27–20:30,
105 sec)
Hands-off. Let the sequence run.
If you see something dramatic (strong prominence, especially clean diamond ring) — tap
Share once or twice to flag a frame, without interrupting the sequence
Look up. Spend at least 60 of these seconds with your own eyes, not the screen.
T-minus 15 sec to 3rd contact
Watch for the diamond ring reappearing on the opposite limb — that's your cue
Filter back on immediately once direct sunlight returns
After totality
Stop timelapse once you're satisfied with the partial phase afterward, or let it run through
3rd contact + a few minutes if you want the full sequence
