Hi guys ,
This the ChatGPT answer
- Measured minimum β true optical minimum
The software measures an approximation of sharpness (usually HFR β Half Flux Radius).
However:
The measurement is noisy (seeing, turbulence, sensor noise)
The stars used can vary from one frame to another
Sky background and guiding also affect the measurement
π Result: the lowest measured point can be slightly offset from the true focus.
π 2. Mathematical curve fitting
ASIAIR doesnβt simply pick the lowest measured value.
It performs a mathematical fit (often a parabola or V-curve) to estimate:
π the theoretical minimum of the curve
This minimum can:
lie between measured points
be influenced by the overall shape rather than a single value
π So the final focus point may differ from the lowest raw measurement.
π«οΈ 3. Seeing (atmospheric turbulence)
Even with a perfect setup:
turbulence randomly βbloatsβ stars
some frames appear artificially better or worse
π A point can look best just by chance.
So the software prefers a global trend rather than a single minimum.
βοΈ 4. Mechanical backlash and hysteresis
With a focuser like the ZWO EAF:
there can be mechanical play (backlash)
the actual position depends on the direction of approach
π ASIAIR typically applies a strategy such as:
always finishing focus from the same direction
compensating for backlash
So the final position may be slightly offset to ensure mechanical stability.
π‘οΈ 5. Drift during the autofocus run
During autofocus:
temperature may change
focus can drift slightly
the optical tube can expand or contract
π The true minimum is actually moving during the process.
π§ Summary
The final focus point chosen by ASIAIR is:
π a robust estimate of best focus,
not simply the lowest measured value.
It balances:
measurement noise
mathematical modeling
real-world conditions
β
Practical advice
Donβt try to force focus to match the lowest point
Instead, check for:
a clean, symmetrical curve
a well-defined V-shape
If the curve is messy β something is off (seeing, saturated stars, too few samples)
