kDB74Thj Seestar_S50 I have a brand new S30 Pro and ZERO rejected frames at 60 sec. As has been commented in other threads, make sure that the base of the eq wedge is level. This is not necessary for eq mounts in general but it is for SeeStar. Then after PA close the arm. Then go to the target. If and when you change the exposure time, close the arm. Then return to the object and start shooting. If you plan to change the exposure time after PA, you can change it first and then close the arm. This saves one arm closure.
Apart from that, always issue a bug report. ALWAYS. With that, there is additional pressure on ZWO to fix things.
