Selard In the latest version of AI Enhancement feature, various enhancement parameters have been made available for users to adjust freely. Different parameter settings may result in different enhancement effects. This feature will continue to be improved and refined through future updates. If you would like to achieve a sharper image result for example, we suggest trying to increase the âDenoiseâ parameter, which may provide a better enhancement effect.
Regarding the frame drop issue, based on your description, the drop rate is still within an acceptable range, which is normal behavior in Seestar's theodolite tracking mode.This is because Seestar performs a quality assessment on each subframe during live stacking. If star trails are detected in a subframe, tracking deviations are found, or the image quality is substandard, that frame is automatically excluded from the stacking calculation. This is to ensure the quality of the final stacked image.
Regarding your mention of constantly losing Wi-Fi connectionïŒmostâoften this is caused by 2.4GHzâband interference. Please restart Seestar and your phone, reconnect after forgetting previous WiâFi profile. If it still does not help, submit the app log so our developers can investigate.
