I have recently been using the SeeStar AS30 Pro in EQ mode and set up a plan as we can't currently commence imaging before 11pm in the UK due to it not being dark enough. So I search for the celestial object I would like to image and give the plan a name. It may well suggest starting at 10pm, but I delay the start time until 11pm and image for 4 - 4.5 hours if the weather is predicted to be reasonable. I then adjust the framing both in magnification and rotation. I save it and ask it to start. The telescope moves to the correct point, but the image I get is not what I have asked for. It ignores the magnification and rotation parts and just takes the usual upright image. I understand that I can do it all manually, but that means I can't set a start and finish time, which is all very frustrating.
Secondly how can I save all the images individually so that I can delete those images which contain satellite or aircraft trails?
