I have the same problem.
My ASI2600MC Pro, which is about 9 months old, repeatedly has problems transferring the data from an exposure to the ASIAIR Plus via USB 3.0. I have also tried USB 2.0, but unfortunately this did not solve the problem either.
The data transfer simply hangs, and I have to stop the imaging sequence and restart it. After another one or two exposures, the same problem occurs again.
The power supply is stable and more than sufficient, and replacing the USB cable did not solve the problem either.
Strangely, the problem usually occurs while setting up an imaging session. Only after several restarts, switching between different USB connections, and completely restarting the ASIAIR (and therefore also the camera) does the problem eventually disappear. Once it is working, I can then image for several hours without any further connection dropouts.
However, getting it to work in the first place can be a very frustrating and nerve-racking process.
There seem to be quite a few similar reports and experiences online. Could the problem possibly be related to the camera's internal USB controller or USB interface?
Is there perhaps a firmware update available for the camera, or is there a repair/service solution for this issue?
Any advice or suggestions would be greatly appreciated.
