PMTeam@ZWO I have tried both ASIAIR 3.0 beta versions, and as other users have already reported, the incorrect contrast issue in the guiding screen with the ASI2600MC Air/Duo is still present.
The other issue is also still present: when guiding through 6 nm and 3 nm narrowband filters, I now need to use Bin 2 and 3-second exposures to achieve stable guiding.
If I remember correctly, with ASIAIR version 2.3.3, guiding worked very well through narrowband filters using 2-second exposures, gain 380, and Bin 1.
Regarding the downgrade procedure, I performed a firmware reset to try to go back to the original ASIAIR 3.0 beta version, because guiding performance seemed slightly better with that version compared to the latest beta. However, when I launch the ASIAIR app after resetting the firmware, it immediately asks me to update the firmware, and I have no option to refuse or skip the update. Could you please explain how I can remain on or return to an older firmware version so that I can properly perform the comparison and submit the two Bug Reports you requested?
I am using Android.
In any case, I am also already in contact with your support team via email regarding these issues.
@Eric , are you also still experiencing guiding problems when using narrowband filters?
