Subject: All-Sky Polar Alignment "Preparation" screen has no cancel/back option
Hi all,
I'm using an ASIAIR Plus with an ASI120MM Mini configured as Main Camera (since my Sony A1 II is not supported). When I tap "PA" to start All-Sky Polar Alignment, the app shows the "Preparation" checklist screen (the one listing the 4 steps: RA axis northward, connect camera/mount, point at visible sky, RA will rotate 30° west).
The problem: this screen only shows the start arrow button on the right side. There is no cancel/back button. Tapping the back arrow (top left) makes the "ASIAIR" title briefly flash to "return" and then jump back to the same screen — it doesn't actually exit.
Closing and removing the app from multitasking doesn't help either — when reopening, the app goes straight back to the same Preparation screen.
The only way I've found to get out of this state is a full power cycle of the ASIAIR unit.
App shows "up to date" under Info, so this isn't fixed by the latest update.
Is this a known issue? Is there a proper way to exit this screen without starting the routine or power-cycling the device?
Thanks!
