Hello,
“Continue to adjust” is a normal prompt during the polar alignment process. It means that the current polar alignment deviation has not yet reached the acceptable range (both deviations need to be less than 1°).
Please follow these steps:
Check the azimuth and altitude deviation values shown in the App, as well as the direction indicated by the arrows.
Loosen the corresponding adjustment knobs on the EQ wedge and slowly make the necessary adjustments.
Continue adjusting until both deviation values turn green and are less than 1°. The “Continue to adjust” prompt should then disappear.
Tighten the adjustment knobs, exit the calibration page, and do not move the device afterward.
Please note: Once the values have turned green, do not tap the “Refresh Deviation” button. Simply exit the calibration page. If the initial adjustment was relatively large, we recommend exiting and performing the precise alignment again afterward for better accuracy.
