New feature, before release, AI can help you code it up, if you need, should not take more than 1 man week to impliment.
Add a 5th "type" to the "Create new sequence" from the + in "plan" and "AutoRun", since they use the same dialog box most likely.
Type: "Control", then Actions would be, On what: "output #1-4", action 2 (On / Off). If output is configured as "FlatPanel" then show "power setting level." If output is configured as "Other(s)", then only thing is "On | Off" value to display.
This way I can fully sequence the control of my DeepSky Dad OFP2.
Like I said, should not take more than a man week to code up if you guys know your software.
These FlatPanel 'like' controller auto open/close are becoming super popular from Rend-a-Pier observatories (StarFront) and others, and people with their own outside observatories.
🙂 Now I let you get on it to your coding.
