you can set the guider rate in your hand controller
the default guider rate usually only 0.5X tracking rate
so it's very slow compare with slew
you need to select "ASCOM" in PHD's telescope menu
and then choose the "celestron telescope driver ascom"
then it's no business of ST4 now
PHD will pick the image from camera and control your mount through RS232
