This is my FC txt-file for the capture above.
FireCapture v2.5 beta Settings
Observer=Bart Declercq
Location=Denderhoutem N50°55' E4°01'
Scope=30cm OrionOptics UK F4.7 Newton
Camera=ZWO ASI224MC
Filter=L
Profile=Jupiter
Diameter=39.85"
Magnitude=-2.21
CMI=253.0° CMII=228.6° CMIII=226.6° (during mid of capture)
FocalLength=6050mm (F/20)
Resolution=0.13"
Filename=Jup_044044_20160108_L.avi
Date=20160108
Start=043959.356
Mid=044044.359
End=044129.363
Start(UT)=043959.356
Mid(UT)=044044.359
End(UT)=044129.363
Duration=90.007s
Date_format=yyyyMMdd
Time_format=HHmmss
LT=UT
Frames captured=8925
File type=AVI
Extended AVI mode=true
Compressed AVI=false
Binning=no
Bit depth=8bit
ROI=480x480
ROI(Offset)=392x208
FPS (avg.)=99
Shutter=10.00ms
Gain=300
USBTraffic=90
HardwareBin=off
HighSpeed=on
Brightness=10
WBlue=99
AutoExposure=off
AutoHisto=75 (off)
SoftwareGain=10 (off)
Gamma=1 (off)
WRed=55
Histogramm(min)=0
Histogramm(max)=198
Histogramm=77%
Noise(avg.deviation)=7.62
Limit=90 Seconden
Sensor temperature=11.0 °C
