Thanks, but that is not what I really wanted. I know that I can calculate the gain myself (there are various methods, some more accurate than others) and I'm familiar with the graphs that you supply for your cameras, but I want to know how you came up with the driver gain settings in decibels (dB). Are those values based upon internal sensor settings or can they be calculated from the actual gain values in e-/ADU?
Like I asked earlier, if unit gain is 1 e-/ADU then why does the ASI174 driver use a value like 189 to represent that setting? Obviously, 189 (or even 18.9 dB) is not equal to 10 log (1/1).
I think in a previous post (somewhere) you showed how the driver gain settings were calculated based upon a set of values taken from the camera, that's what I want to know. Unfortunately, I can't find that post using your site's search feature (if the post even exists).
I'd like this information for the ASI178MM-Cool, which apparently has a unit gain near 0bB which makes some sense as 10 log (1/1) = 0, but then why is the gain at 0.25 e-/ADU represented by a driver setting of 100? A change like that in decibels should represent a factor of 10, not just 1 to 0.25 or a ratio of 4.
Since you indicate that the driver values are in 0.1dB units I'd think that they must represent some actual measurement or setting in the camera, they can't just be numbers picked along some meaningless number scale.
