Hi,
I have a problem with detecting 174MM camera on my laptop with x64 Windows 7 OS. It is not found in the devices after connection. I've reinstalled the all newest drivers.
My 224MC camera works fine. Could please help me to find solution?
Thanks in advance.
can you see this device under "device manager"?
Sam wrote:can you see this device under "device manager"?
Hi Sam,
No I can't see it under device manager, but during connecting/disconnecting I can hear the sound which informs that some device is detected. Looks like there is some problem with installing hardvare drivers or something like this.
I've installed driver "all ASI cameras in one" marked all required checkboxes during instalation.
I think there must exist a unknown device when you plugin the camera
you can do a manual driver update of the unknown device by point the driver directory
Sam wrote:I think there must exist a unknown device when you plugin the camera you can do a manual driver update of the unknown device by point the driver directory
And what driver should I use for this?
During connection camera to my laptop it is detected as some strange device:
After deleting driver for this device and reconnection situation is the same.
I can't get how to install/update driver manually.
Look under imaging devices instead with the camera connected. When you hear the sound (ding dong) when the camera's USB cord is plugged in, it means that the camera is recognized.
Regards Leif.
Landbo wrote:Look under imaging devices instead with the camera connected. When you hear the sound (ding dong) when the camera's USB cord is plugged in, it means that the camera is recognized. Regards Leif.
Thanks Leif,
But I've checked under imaging devices and there is no this camera avaliable, and redlined device appears when I plug in camera, and disappears when I disconnect it. There is no doubt that camera is recognized as this strange device.
I have the same camera and computer.....
The screen shot shows my installation of the ASI 174MM.
No issues with USB connection etc.
(I just used the drivers sent with the camera)
