Hi guys.
Just took delivery of my new 120MM-S.
I chose this specifically over the standard 120MM for the USB3 capability and claimed faster frame rate. However, my testing has turned up an unexpected result.
My laptop has three USB ports. 2 are USB 3 and the third USB 2.
When I plug the camera in the USB ports and have the screen size set to max (1280x960) I get a frame rate of 22.86fps in the USB 3 ports.
The USB2 port returns a rate of 27.82, with all other setting being the same.
How is this possible? What am I missing here?
I have a ton of RAM (16G) on my machine. It is an ASUS 'Republic of Gaming' machine. It has an Intel Core i7 2.6GHz processor, operating at 64 bit.
I also own a 174MM and 224MC and both these cameras perform as expected when plugged in to USB3 Vs USB2. They run much faster in the USB3 ports.
I was hoping for generally faster frame rates and more specifically, better fps under USB3 than USB2.
Any help much appreciated
