Hi vlav,
I have the ASI185 cooled and I hope I could help you a little bit.
Here is the first test I made with 8 seconds subs in 8 bits (sorry in french...)
http://www.webastro.net/forum/showthread.php?t=133707
Amp glow is visible, I don't use here the preset values for deepsky imaging
as Firecapture don't support ASCOM.
For deep-sky imaging with exposure time more than 1 or 2 seconds, it's
necessary to use the same way as for long exposure imaging.
So use only 16 bits raw images and darks. All processing in 16 bits,
don't mix 8 and 16 bits images. Be careful for darks, use exactly the
same exposure/gain/color balance and a nearly constant temperature
Use the ASCOM driver with a deepsky imaging software that support it.
You have 3 preset configurations very usefull to reduce 'amp glow'
(in the last driver available).
Now I'm waiting for clear skies (1 month and half with clouds, fog, rain... : ) to
make longer exposure images. ;)
Albéric
