james1ca wrote:firstC8 wrote:BTW it is remarkable your above 180s DF has no hot pixels.
It was a fairly moderate stretch from a cooled camera. If I stretched it further then it would have obvious hot pixels.
Are your results from one of the cooled ZWO cameras?
Interestingly, I don't think I've ever had a problem with mismatched bias files, at least not on the cooled ASI178MM. However, the dark fields are another matter (hard to get matched darks, even at the same gain, exposure, and set point temperature).
My above camera is by QHY but the chip is the same as ASI120MM. All the talks about the darks are different from different sessions make me nervous. I am planning a trip to a remote dark site, if I have to do live dark frames along with the respective lights, I will have to go there for several sessions, a near impossible task.
