OldSkyEyes wrote:That's a good reference with your C8.
This max. 3 guide stars was this with f/10 or f/7?
You do use a color version so I don't know yet with which factor I can increase the sensitivity but I guess it would be at least 1 magnitude more sensitive (based on the spectrum filter) . Which should results result in 3x extra stars, or about 3+9 guiding stars)
Prime focus F10. At your F7 with C11 my guess is it is equivalent to my C8 at F10.
Hopefully you don't use the Celestron OAG, it is designed for F10. With the reducer the light circle is smaller, you need an OAG that can extend the prism in further.
Depending on your mount quality, my AVX mount is the lowest budget goto mount out there, it requires 0.5s or less exposure in PHD to handle the bad periodic error. Seeing condition must be good enough to do 0.5s or less. If seeing is not good enough to support short exposure, I probably won't image with C8 at F10 anyway.
With a better mount exposure time should be able to increase. The longer exposure, the more stable your guide stars.
