Hello,
the C9.25 at f6.3 with the ASI224MC has a sampling rate of 0.5 arc sec / photosite, this is very small and seriously resembles a typical sampling rate for planetary imaging at high resolution. To fully exploit such a resolution, exposures have to very short to avoid turbulence blurring, e.g. 0.5 second up to 5 seconds, as long as the deep-sky objects are contrasted (M51, M13, M57...).
I've shot this way at f/4.7 (see my early posts with the ASI224MC and others with the ASI120MM which has nearly the same sensitivity but 8x more noise).The ASI224MC should work at f/6.3 too, for contrasted objects.
