Still new to this.
Here is a single image (i.e., unstacked) of the Moon made with the ZWO ASI120MC using an 80mm short tube f5 telescope, captured with FireCapture. The image was extracted from the avi file with VirtualDub.
I include the FireCapture log because I find it very useful in trying to learn how to use the ZWO and software to see what others used to create their images.
FireCapture v2.4 Settings
Camera=ZWO ASI120MC
Filter=RGB
Profile=Testing
Diameter=42.13"
Magnitude=-2.34
CMI=219.9° CMII=39.4° CMIII=45.3° (during mid of capture)
FocalLength=8100mm
Resolution=0.10"
Filename=Testing_024654.avi
Date=290116
Start=024654.915
Mid=024709.931
End=024724.947
Start(UT)=154654.915
Mid(UT)=154709.931
End(UT)=154724.947
Duration=30.032s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT +10h
Frames captured=548
File type=AVI
Extended AVI mode=true
Compressed AVI=false
Binning=no
ROI=1280x960
ROI(Offset)=0x0
FPS (avg.)=18
Shutter=0.558ms
Gain=23
Brightness=0
WRed=52
AutoExposure=off
HighSpeed=off
USBTraffic=80
WBlue=95
SoftwareGain=10 (off)
Gamma=51
Histogramm(min)=0
Histogramm(max)=255
Histogramm=100%
Noise(avg.deviation)=1.42
Limit=30 Seconds
Sensor temperature=76.1 °F
