Firecapture allows you to define just about any size of ROI in any location within the field of view and I'm wondering how that is done with the ZWO cameras like the ASI178MM. In fact, I have read that software may use binning and line skipping to create these non-standard ROIs and if that is true then it would seem that they might degrade the image quality produced by that ROI (if the binning and line skipping happens within the captured area of the frame).
Thus, are there limits on the size and location of an ROI in order to make certain that you always get the best possible image quality? Does the ROI always have to be taken from the upper left corner of the field (to maintain full quality)? Does Firecapture's "Center ROI" option have any effect on the captured image quality?
For the ASI178MM I see the following values for the "Default" (standard?) ROIs in Firecapture:
100 x 100
200 x 200
300 x 300
400 x 400
640 x 480
800 x 400
600 x 600
1024 x 768
Are all of these values directly supported by the IMX178 sensor? Can these "default" ROIs be repositioned anywhere within the frame without affecting the captured image quality?
In any case, I just want to know what ROIs (and locations within the frame) are actually supported by the ASI178MM hardware.
