Hi All,
I am used to DSLR astrophotography, but a novice to "webcam" type astrophotography, so please can experts amongst you help?
I got a ZWOASI178MC camera and got the chance to use it on Jupiter. Captured the images with FireCapture and processed in RegiStax (both up to date versions). Results were horrible -- Jupiter came out as a flat green circle in final image!
Any advise will be much appreciated, but importantly can you tell:
(1) Should the capture exposure tend to minimum or maximum milliseconds?
(2) What should the Gain be (Default is set as maximum)
(3) Should the Gamma be on (default is off), and if so what level?
(4) Which of the three file formats offered best -- SER, FITS, TIFF?
Many thanks in advance -- I am also new to this forum, and a little uncertain how to use it to best impact !! :
