Are you using ROI (smaller frame) for Jupiter? Then it should allow much faster framerates. Also exposure time must allow it (if you use 1/30 sec exposures then only 30 FPS).
For Jupiter at max telescope resolution I usually use somewhere between 10-20ms.
