I'm dealing whith a problem with asi 120mm.
When I try to capture Deep Sky (Shutter speed >1sec) 12 bit pictures full frame (1280x960) via Firecapture2.4, in most of the cases capture fails or stops and eventually restarts splicing the picture.
No problem at faster shutter speed (<1sec).
I tried to reduce the USB traffic but it has no apparent effect
The only way to overcome the problem is to reduce the resolution at least at 960x960 or to choose 8bit sampling, in wich case the output is correct and steady.
The asi120MM driver is updated to ver. 2.7
Thanks in advance for any suggestion.
Maurizio.
