The camera does appear in the device manager on both tablets.
I was able to get my Dell tablet up and running with the camera, flashed back to it's factory firmware. I have had zero luck getting a powered USB hub to work, so I can only run as long as the battery holds out as the same USB port is used to power the tablet as is used for cameras or external storage.
It is clear the performance of the tablet limits its data capture rate, but I was able to capture Jupiter and Lunar AVI's last night.
Some additional notes:
1. The Dell tablet running Win 8.1 seems slightly incompatible with Autostakkert. I can load AVI's or BMP's, and analyze them, but the alignment wind disappears and cannot be STACK button remains greyed out no matter what I do. I will generally post process on a more robust machine, so we will see.
2. The Winbook will not see the camera in any software, firecapture, etc. its too bad since that tablet has a dedicated USB port plus a power/USB swing port. There may be a USB hub inside the thing that is messing things up.
3. While I have a working solution with the Dell tablet, I really need to pursue an ultraportable laptop with a proven track record with these cameras.
