I am using a ZWO ASI120 MCS on Firecature 2.4 on a windows 10 - I am finding that many of my captures are currupted, refusing to open. if I reduce the capture time to 1 minute it os OK but will not take a 2 minute. I am capturing at 85 fps. I get a Oxc00d36c4 message. If I reduce the frame rate it usually is OK. Sharpcap does not give me this problem. Can anyone help
1. what's the usual size of corrupted files? (is it AVI?)
2. try pausing recording and then stop after a second or two. Does that help?
riklaunim wrote:1. what's the usual size of corrupted files? (is it AVI?) 2. try pausing recording and then stop after a second or two. Does that help?
The average size is 4-5 GB yes its a AVI but I have not tried pausing before stopping, thanks
There are some AVI size limitations which may break the file for other apps. If pause won't help try SER format for such big captures.
riklaunim wrote:There are some AVI size limitations which may break the file for other apps. If pause won't help try SER format for such big captures.
Many thanks, I will try that, Im not sure that Firecapture handle SERs
You can choose that format in FC.
riklaunim wrote:You can choose that format in FC.
Thanks
Robindurant wrote:riklaunim wrote:You can choose that format in FC. Thanks
Hi all, just found out the problem, my fauly, I had not clicked the box in "Capture setings" to capture over 4GB, just tested on 15 GB, it works OK
