Thanks for the quick feed back, but i am a real beginner on Linux, so i don't know how to get the requested infos. If u could give me the command to run or where to look ?
Here also u will see the output in the terminal when i launch cheese :
pi@raspberrypi:~ $ cheese
** Message: cheese-application.vala: Error during camera setup: Aucun périphérique détecté
(cheese): cheese-CRITICAL **: cheese_camera_device_get_device_node: assertion 'CHEESE_IS_CAMERA_DEVICE (device)' failed
(cheese): GLib-CRITICAL **: g_variant_new_string: assertion 'string != NULL' failed
(cheese): GLib-GIO-CRITICAL **: g_settings_schema_key_type_check: assertion 'value != NULL' failed
(cheese): GLib-CRITICAL **: g_variant_get_type_string: assertion 'value != NULL' failed
(cheese): GLib-GIO-CRITICAL **: g_settings_set_value: key 'camera' in 'org.gnome.Cheese' expects type 's', but a GVariant of type '(null)' was given
** (cheese): CRITICAL **: cheese_preferences_dialog_setup_resolutions_for_device: assertion 'device != NULL' failed
