Hello,
I am using for 2 years the ASI120MM in conjunction with a Windows 7 64bit and it works in every Situation very well.
Regarding the age of my Notebook and because, I am afraid, that it fails soon, I bought a new one with the OS Windows 10 Home 64bit. And now, using this camera, I have very big Problems to use them with FireCapture (and additionally SharpCap).
I installed FireCapture Versions 2.2, 2.3, 2.4 and 2.5beta (I tried both the 32bit and the 64bit Version).
Following Problems occur:
Capture failed very very often.
I reduced USB-traffic to 40. But only very small ROIs (120x128 until sometimes 320x240) are working. Oftenly Capture failure appears and/or the Frame rate is reduced to Zero or 3 until 5 fps. But the expectation should be 50 to 60 fps depending on the ROI. And sometimes, fps jumps between high fps and low 3 or 5 fps for small ROIs.
The Java Version, I use, is Version 8 Update 77 (Build 1.8.0_77-b03), if it is important for the discussion.
Furthermore, I use the newest Firmware for the 120MM.
I have no idea, how to solve this.
Unfortunately, I wanted to buy a ASIxyz-USB3.0 camera, but now, I am afraid, that I will get the same Problems.
Is there anyone, who had the same Problems and knows a solution?
I would be very grateful for fruitful hints.
Best regards
JoachimH
