Hi! it appears that I have run into the same problem that I had with the ASI120MM. I now have the ASI224MC and it won't connect to any type of USB hub. I tried using an ICRON Ranger 2304 and through the mount USB connection. The only way it will connect is directly to the Laptop. Is there a remedy to this? Thanks!
William
