Thanks for the reply!
I'm really looking forward to getting that new camera. From what I've seen of the ASI224MC it should do a good job. If the ASI290MC is better than the DMK camera, I'll be quite happy. The larger sensor and smaller pixels will make centering the subject planet much easier. I will just be using whatever filter comes with the camera. Most often I'll be using a Celestron-11 @ 2900 mm (without Barlow). The small pixels of the 290 camera gives a nice 1.9X sampling. If I experience excellent seeing (which is very rare), a Barlow would up that to 3.9X.
With the old mono camera, I never got into the use of filters for color imaging. Here's the best I was able to do:
http://www.dpreview.com/forums/post/57490708
I'm hoping the color camera won't be too inferior to what a mono camera could produce. The one shot color method has improved over the years. So I'm looking forward to seeing what results.
Thanks again for getting back to me.
Best Regards,
Russ
