the resolution is 4656*3520 3.8um
so effective area is.7mm*13.3mm, diagonal is 22mm
if you use our filter wheel,the surface of the filter to the CMOS is around 10mm
1.25" filters usually have 24 diameter
so supported focal ratio scope without vignetting should be more than 10/(24-22)=F5
