Rodmac wrote:I'm new to this forum and still trying to work out which camera to get as a starter so my question is would the 178 colour camera work well for guiding through a 80x400 guidescope? and for planetary and some dso imaging through a 10" F4 Newtonian?
Or am I better going for something that will perform best as a guide camera - if so what would people suggest?
Cheers
Rod
Hi Rod
I have the 178MC and can't fault it.
I use it for Guiding, Planetary and some DSO. You have to mange your expectations...for guiding and planetary it's great. For DSO it works well, but you will not get the same results as you would for a £1100+ camera. I have the 1600MC with Hyperstar lens at F2 on a C11, or F10 from the back of the C11. The results are far better than the 178MC, but the 178MC is a 3rd of the price.
The way I see it...Start with the 178 or 224. It will satisfy your needs for now. If, at a later stage, you want more, then either of these will still be valuable as guide and planetary.
Good luck and hope you get the results you want.
Cheers
Chris
