I had a similar problem, I don't know whether it's related.
The first time I used oaCapture on my Mac (el capitan) with my ASI174MM everything went ok, since I did not change camera settings, just gain & gamma. The second time, though, I started playing with the parameters to get a faster image rate, and after some changes, the software started freezing and making everything very very slow (unusable!). I disconnected the camera from oaCapture, and the speed went back to normal, but selecting it again caused the program to freeze again...
This behaviour went on every time I connected the camera and activated it in oaCapture. I tried changing every setting (at slow motion), restarting, smc reset, etc. but nothing changed.
I tried the camera in another machine (firecapture on windows), and it worked fine.
In my case, the solution that worked was to delete the preferences files for oaCapture. They are in the Library/Preferences folder of your user folder (search for oacapture in that folder, they have a .plist extension). After deleting those files and firing oaCapture, the camera worked again in my Mac.
If it is not your case, I hope someone finds this experience useful.
Anyway, does anyone know which settings (in the camera tab I guess) could be guilty of this malfunctioning?
Regards from Barcelona (Spain),
Jordi.
