Took me some time to get back..
Peter, it's good that you got a solution for your use.
Not sure why someone was saying "..you do lose some light even with the best flip mirror". The idea was to use the 90° exit only for visual adjustments. There's no mirror in the straight through path, no translucent mirror construction here. Just saying so no one is getting more confused than necessary :)
Yes, you should not need the Flip-Mirror with a color cam, FireCapture has dedicated assistance in that case.
For mono though, and anyone interested in the Flip-Mirror, yes, I made it work ZWO ADC, Baader FFC, C11HD and ASI290MM.
Much magnification though, just on the right side with Jupiter and similar, using filters RGB or the bright IR642. Rather dark with IR742, really too dark with IR807, and nothing to be seen no matter camera settings using ZWO CH4 or Baader U.
Operation was absolutely fine though, the Flip-Mirror is smooth and precise, and it was quite easy to adjust the ADC with an EP.
You do need to order the odd 49mm stepdown adapter though.
I like this setup a lot, and will continue using it.
But for the other cases requiring more light and less magnification, I recently got a "special edition" of the Gerd Neumann dual slider. Shortens length significantly. Only tested it once yet, a really well made piece. So far it seems that the slider is really what most of us should get if using an ADC with a mono cam.
If anyone is interested I can make a complete writeup with photos.
