Good morning I just received a new zwo asi224mc with fisheye skyview lens. I have a Celestron 6SE scope and need to know how to connect the fisheye lens to the camera and then to the eyepiece on the scope. I whish to connect to a barlow eyepiece.
You do not use the fisheye and the telescope.
You remove the fisheye and replace it with the nose piece and insert it into the Barlow, then focus.
David
David Staup wrote:You do not use the fisheye and the telescope. You remove the fisheye and replace it with the nose piece and insert it into the Barlow, then focus. David
So how is the fisheye used for all sky viewing
You leave the fisheye in place and point it up...
