Sam,
Have you folks published the Bayer Matrix for this new camera?
Thanks!
it's GRBG
Hello, what is the consequence of imaging with RGGB with a zwo 1600 even if the pattern of the camera is GRBG ?
If i set the right matrix bayer in the preprocessing step it should correct that ?
Regards
Mourad
Hi Mourad,
If you use wrong bayer matrix, it will like the attachment.
You can use SharpCap to select the force debayer to make a test.
Thanks
Chad
